930 Comfort King Loader
Brangus1
01-15-2005 16:19:21
Is there a Loader available for this tractor? I've been told that there is none available for the 930's with a cab. Appreciate any help, new or used.
napaguy
01-16-2005 09:38:09
 Re: 930 Comfort King Loader in reply to Brangus1, 01-15-2005 16:19:21
you need a model 70 case laoder. they were made for case by great bend. i have one on an 830 that also fits on my 1070 with a cab.
Roger H
01-16-2005 11:45:01
 napaguy in reply to napaguy, 01-16-2005 09:38:09
Are the mounts the same for both tractors? do you have a set for each tractor or do you move the same ones from one to the other?
Roger H
01-15-2005 16:25:23
It may not matter, but are you talking about a later one with 8 speed or an earlier one with 6 speed & round fenders? I have a '67 8 speed western with a cab & loader, I'll email some pics.
Brangus1
01-15-2005 18:49:22
 Re: 930 Comfort King Loader in reply to Roger H, 01-15-2005 16:25:23
I don't have the unit at my place yet. Does yours hook up to the rear axle or to the block??
Thanks for any help and direction on this!
Roger H
01-15-2005 20:34:18
 Re: 930 Comfort King Loader in reply to Brangus1, 01-15-2005 18:49:22
My loader is an Ezee On made in Canada, it is a quick tach unit that has the sub frame always mounted to the tractor, it is bolted at the front next to the radiator, then some bracing under the front of the cab, then it also reaches back to the rear axle to brackets on the axle. All I have to do is flip up a latch on each side in front of the cab & start backing away, once it gets slid part way off, I pull the lever like I would be raising the bucket & the rest of the frame will set on the ground to act as the stand until I put it back on. It is very easy to put on or take off. I'll get some closeup pics of how it's mounted tomorrow & send them.
Jeff from WI
01-15-2005 21:09:47
 Re: 930 Comfort King Loader in reply to Roger H, 01-15-2005 20:34:18
Hi Roger, I Sure would like to see some pics too. Thanks Jeff From WI.
Roger H
01-15-2005 21:13:39
 Re: 930 Comfort King Loader in reply to Jeff from WI, 01-15-2005 21:09:47
Ok Jeff I'll send some to you too.
