how to unstick engine on TD18 international harves
one armed
01-15-2005 12:35:31
Engine was running but pulley on the front was
spinning. I shut it off, ordered pulley and
got it put on and then it would not start. It was covered, but I thought moisture could have gotten in-just don't know. I hope someone can help me
and I hope I don't have to take the "head" off
I think I just want to unstick the engine.
caseman-d
01-15-2005 16:32:42
 Re: how to unstick engine on TD18 international ha in reply to one armed, 01-15-2005 12:35:31
Judging from what you say I would look at the pulley you installed. I gather that the pulley is the crankshaft pulley??? Have you tried turning it by hand or are you just trying the starter?? If its the crankshaft pulley you didn't get your belt to tight??? You might pull the starter and make sure it's not locked up against the flywheel. Also you might try putting a socket on the dampner pulley bolt and try turning it that way. Unless it's been months since you last run it I don't see how the engine could be stuck. I haven't been aroud the td18? Does that start on gas and switches to diesel or is it a straight diesel. If it has set and has the posibility of water in the cylinder depending where your at it could be frozen. Might try pulling the injectors or plugs to see if that doesn't help.
caseman-d
comfortking
01-15-2005 12:56:36
Are you sure that the pulley you put on is not the problem? You did not say how long it was not running. Should come loose easily maybe try to get to flywheel and rock it if is not tight on the pulley.
