Radiator Hoses and Thermostat, 430 (441)
Mighty
01-14-2005 18:31:55
I just ordered the bottom radiator hose for my 430 from the local dealer, but he indicated the top hose was no longer available, nor was the thermostat that is located in that upper hose.
Any suggestions where I might find the hose/thermostat combination? The hose looks like a straight 2" hose, but if I replace it with only a length of standard hose (as the parts man suggested), the system will be without a thermostat.....
Thank you in advance for any help or suggestions
Joe Young
caseman-d
01-15-2005 10:18:12
 Re: Radiator Hoses and Thermostat, 430 (441) in reply to Mighty, 01-14-2005 18:31:55
If your still looking for one email me at [email protected] and I will do some checking for you.
caseman-d
Mighty
01-15-2005 16:53:26
 Re: Radiator Hoses and Thermostat, 430 (441) in reply to caseman-d, 01-15-2005 10:18:12
Thank you for the offer. I went back to the dealer this morning and found the parts man did locate the correct part number. I now have a thermostat on order. Thanks to all who replied....
case poor in pa
01-14-2005 19:22:24
i just bought a inline thermostat this winter from my case dealer.. for my dozer. if you cant find one get hold of me and ill check there for ya.. was like 35 bucks tho...
Mighty
01-15-2005 02:50:52
 Re: Radiator Hoses and Thermostat, 430 (441) in reply to case poor in pa, 01-14-2005 19:22:24
Thank you for the heads up. Mr Parts Man may need to look a little harder....
Keith-OR
01-14-2005 20:12:11
I just used striaght hose and found a thermostat of the correct temp, ground it down to fit just inside the hose. Then put a hose clamp on hose just where the stat would be. Working well so far.
HTH...Keith
Mighty
01-15-2005 02:52:09
 Re: Radiator Hoses and Thermostat, 430 (441) in reply to Keith-OR, 01-14-2005 20:12:11
Thanks for the idea Keith...
