Case engine
Rockcricker
01-14-2005 16:07:42
Just got a old 48 sc that hasn't run in ten years. I had my wife pulling me to just turn the motor over and then it would not do it anymore. What could be the problem?
C. Amick
01-14-2005 18:25:36
 Re: Case engine in reply to Rockcricker, 01-14-2005 16:07:42
The clutch may be slipping. If you don't have a crank, put a 3/4-inch drive ratchet and socket on the big belt pulley nut and turn it make sure the engine is still free. If you didn't check to make sure all the valves were free before you started turning it over, you may have some bent push rods, if any of the valves were stuck, but that's a whole different problem.
Camboted
01-14-2005 16:41:33
Did the engine freeze up or the engine just stop turning while you were pulling the tractor? If the latter see the post below, you need clutch work.
