DC clutch
Kirk-Tx
01-14-2005 14:34:21
I was pulling a DC trying to crank it. It has a hand clutch. It was working fine, then just released while it was pushed forward & would not engage again. I removed the cover to inspect but did not see anything obvious. (Didn't know what to look for). Tractor hasn't ran for years. We had it firing and trying to run till this happened. Any ideas would be appreciated.
Camboted
01-14-2005 16:38:59
 Re: DC clutch in reply to Kirk-Tx, 01-14-2005 14:34:21
Having just pulled 4 apart I'll tell you that you might as well spit it, because you probably need a new clutch plate. Every one of the DC's I pulled apart had clutch problems even though three of the four still worked. It sounds to be like your clutch disc has split and broken up, especially if you mechanical parts, pressure plate arms, and through-out bearing and springs look good
Kirk-Tx
01-14-2005 18:12:28
 Re: DC clutch in reply to Camboted, 01-14-2005 16:38:59
Thanks for the reply. I was afraid of that. Is there anything else that I should check and/or replace while inside?
Camboted
01-14-2005 20:27:39
 Re: DC clutch in reply to Kirk-Tx, 01-14-2005 18:12:28
Check your pressure plate springs, they are often broken, sometimes the cast hooks on the pressure plate are broken (they can be welded)then of course, the pilot bearing and throughout bearing, check the surface on your flywheel and pressure plate, should be ok, but if badly scored you can have them surfaced. You may want to put in new bushings on the clutch shaft and check your forks to make sure they are in good shape.
Camboted
01-15-2005 03:45:11
 Re: DC clutch in reply to Camboted, 01-14-2005 20:27:39
Just so I don't get you confused, the hand clutch unit uses a throughout sleve, not technically a bearing.
