Case electrical
markloff
01-11-2005 22:44:01
Hello,
Three questions:
-what"s the difference between a six and twelve volt generator? Will a six volt generator put out 12 volts with a 12 volt regulator?
-my Case 401 service manual says Case used both a Delco and an Autolite setup for the generator and voltage regulator. Did the Delco setup have the voltage regulator mounted directly on the generator or remotely mounted? Some one mounted a prestolite generator with the regulator mounted remotely on mine at sometime, Case never used one did they? It"s interesting to note that the Autolite amp output was listed in my service manual at 4 amps and the Delco at 40 amps could this possibly be a misprint? Any one have an original setup they would like to sell?
-second question. I always see guages listed on ebay for the earlier letter series Cases. How different, if any, are the 400 series?
Thanks,
Mark
mEl
01-12-2005 04:19:22
 Re: Case electrical in reply to markloff, 01-11-2005 22:44:01
There's gonna be some comment pro and con about this but my boss has a late DC that I converted to 12V for him. I just removed the cover on the v-reg. and set the voltage control section up to 14V, allowed it to run a while to make sure it was stable, buttoned it up, years later it still works fine. mEl
