Unleaded gas for the old CASE
Greenfrog
09-04-1999 22:39:04
I have a 42 SC and 54 DC. Should I use lead additive to the unleaded gasoline. Should i also put in a inline gas filter, as they tell me that todays gasolines contain fine particles that are bad fo the needle valve seats in the carb. thanks in advance. Greenfrog is a old CB handle.
Steve
09-16-1999 22:59:45
 Re: Unleaded gas for the old CASE in reply to Greenfrog, 09-04-1999 22:39:04
Greenfrog,
I've had a '49 VAC for 3 years now, and am the second owner of it. I haven't used any lead additives, nor plan to as it runs great on the un-leaded. I did use a lead substituted on a built jet boat that I owned, and I feel that it did more harm than good to it.
Jerrie Lott
09-06-1999 19:59:45
I still maintain that it is a waste of money to put lead additive in gasoline for these old tractors. When I was growing up we never bought leaded gasoline until we bought our 1955 Case DC and it would not run right on the old White gas which was unleaded but was a waste product back in those days so was considerably cheaper than gasoline that you bought at the gas station. I have a 1949 Jd "B" and a 1951 Case VAC and I have never used lead additives in either in the ten years that I have had them and I used the quite heavily for quite a few years, and never have had any sign of the valve seats going out or anything like that.
DL Moore
09-06-1999 16:56:52
Found all kinds of useful information right around the corner, go back to this web sites home page, go to Research $ Info, then Article Archives. At bottom of page is "lead additives"
Deadline
09-05-1999 05:56:07
Have 44 SC, newly restored, from those I've spoke to, they suggest the extra lead to keep the valves from burning up, however that's done. "Deadline" nickname given to me in the service.
Jerrie Lott
09-05-1999 12:01:23
 Re: Re: Unleaded gas for the old CASE in reply to Deadline, 09-05-1999 05:56:07
I really don't think that a lead additive is necessary for the health of these engines I remember when I was growing up and We got our new DC (a 1955 model) We had to start getting what Dad called "red gas" because it had higher compression than the SC and would not run on "white gas". Back then white gas which was cheaper than red gas because it did not have lead added to it. Lead was added to boost the octane level of the gasoline but it did also add a slight layer of cushioning to the valves. These old tractors do not have that heavy of valve springs and do not run of that fasr of an rpm to really need this cushioning I never heard of the valves being beaten out of one of these old tractors before people started using leaded gasoline.
