More on my 51 VAC Diff Axle
WOD
01-10-2005 20:05:17
Well,
I got the old seals out of the bearing carriers.
When I examined the race I notice it was worn in one spot about 1.5 inches long. The was no lip left for the seal to ride against. I suppose
I need to replace this bearing and race. How do
you get this bearing off? It seems to be pressed on.
Thanks,
WOD in VA
Augie
01-11-2005 09:10:44
 Re: More on my 51 VAC Diff Axle in reply to WOD, 01-10-2005 20:05:17
The pinion bearings are pressed on. Clamshell puller and hydraulic press is the answer.
WOD
01-11-2005 13:22:27
 Re: More on my 51 VAC Diff Axle in reply to Augie, 01-11-2005 09:10:44
The manual states that the side gears come off and that's what the bearing sits on I guess.
How do get the side gears off? Have you ever done this before?
Thanks
Augie
01-11-2005 15:34:30
 Re: More on my 51 VAC Diff Axle in reply to WOD, 01-11-2005 13:22:27
Haven't done it yet. I've got mine split into three pieces and just need to find a bit of free time to tear into the transmission.
New bearings and seals except for that double-lipped unobtanium front input shaft seal have been purchased. I'm hoping that thing can be replaced with a pair of single-lip seals. Will post back here if I can find something that will work there.
From what I see in the service manual the side gears should more or less just pop out once the carriers have been removed.
WOD
01-12-2005 05:46:34
 Re: More on my 51 VAC Diff Axle in reply to Augie, 01-11-2005 15:34:30
I'm going to try and get the gears off tonight.
My manual pretty much says the same thing. I will let you know how it turns out.
WOD
WOD
01-13-2005 07:12:12
 Re: More on my 51 VAC Diff Axle in reply to WOD, 01-12-2005 05:46:34
Well, as it turns out I did not have to pull the side gears off. The bearing and race was fine.
All I had to do was replace the seals. That was kind of tough without something to put over the gear to protect the seal. What we did was oil the seal and diff shaft and then while one pushed up the diff axle the other slid the bearing carrier into place. This had to be done
gently to keep the seal from geting skewed.
Not easy but we got it and now I have brakes.
Thanks,
WOD
Augie
01-13-2005 09:54:10
 Re: More on my 51 VAC Diff Axle in reply to WOD, 01-13-2005 07:12:12
Excellent! Kids are out of school tomorrow so I'm going to take the day off too and work on the tractor.
Augie
01-12-2005 09:07:32
I'm s.o.l. for tonight. Wife has a meeting. Will be running taxi service for the kids and MIL.
