bleeding air from 990
terry noble
01-10-2005 10:18:16
I have a david brown 990 which I ran out of fuel. I need to know what I have to do to get the air out of the system.
Eddie in Ky
01-10-2005 21:44:47
 Re: bleeding air from 990 in reply to terry noble, 01-10-2005 10:18:16
#2 & #3 are with the fuel valve in the run position. Sounds stupid, but I hadn't run mine in about 3 months and forgot to set the fuel lever in the run position. Almost ran the battery down before I remembered it.
Jens Andersen, Denmark
01-10-2005 12:51:44
Pretty simple. 1st, you loosen the breedingvalves
on top of the fuelfilters,most likely 3/8" hexagon, and use the primingpump on the other side
of the engine, until only fuel is coming out. 2nd,
losen the breedingvalves on the injectorpump, and
again use the primingpump. 3rd, lossen the injec-
torlines, on the high end at the INJECTORS, and crank the engine with the starter until you see clean fuel coming out then tighten them down again
and you should be ready to go.
Good luck Jens Andersen Denmark
