Case Model LA water pump.
John Reavis
01-09-2005 12:28:18
Was wondering if anyone knew of source for a new or used water pump for an LA Case engine used as a power unit on a sawmill. Also a radiator core. I believe the assembly no. of the pump is 3282AA. Thanks for any help.
Brian in Ohio
01-09-2005 13:58:55
 Re: Case Model LA water pump. in reply to John Reavis, 01-09-2005 12:28:18
I have a Cae LAE that I'm willing to part out. (Cracked block) If you are interested in the water pump, I'm be willing to make a deal. It has the radiator with it, but I already know that the core is bad in it. It may be money better spent to just put a new core in it from the start and not worry about it going bad on you later down the line. I put one in my 34 L for $300.
Butch/ OH
01-09-2005 13:47:09
I have a used LA water pump.
caseman-d
01-09-2005 13:14:44
Check with Don Livingston 507-433-0073 or if you want to try a used one Don may have that also. Curt Elson may have a used one also 605-892-2795. I do believe a seal kit may still be available from Case if yours isn't to bad of condition.
caseman-d
