SC Case Transmission Locked Up
rgorange
01-09-2005 10:03:28
Last summer I found the SC that my grandfather bought in 1949. It had been sitting outside and not run for many years. The guy that had it last said "it ran fine but the clutch was slipping when he parked it". Since it was close to my brother's place in southern MN, I moved it to a shed there. I am in Indiana, so I have not been able to work on it yet. I took out the spark plugs and 1 has rust and another a bit of rust (I suppose those are the ones with the open exhaust valves). The dealer said the engine is froze. The shift lever moves and feels normal but the wheels are locked. Is it stuck in 2 gears? Is it possible that water got in and rusted the works in the rear end? Just because the clutch is bad and the motor is stuck should not keep the rear wheels from turning should it? Maybe the forks are bent? If I take the top cover off of the transmission will I be able to use a bar or something and move the forks to get it in neutral? Is there a trick to that?
Yes, I know... there is a lot of work to do and I could have found one that was easier to restore. But my grandad and dad owned this SC and I spent many hours on it as a kid. So I couldn't let this one get away.
By the way... this is a great forum. I check it out almost every day.
Thanks guys.
rgorange
C. Amick
01-10-2005 09:19:30
 Re: SC Case Transmission Locked Up in reply to rgorange, 01-09-2005 10:03:28
Tanke the plug out to the bottom of the transmission and drain any water that's in there out. If it's in MN, could it be ice in the transmission? My guess is that it's the brakes that are stuck. I have had this problem.
rgorange
01-10-2005 17:49:51
 Re: SC Case Transmission Locked Up in reply to C. Amick, 01-10-2005 09:19:30
Thanks, I think you and Don L. have it. Not Ice.... I was in MN in summer and it was stuck. I recall that the shift lever moved and felt like it was working properly but the brakes DEFINITELY did not feel right. It did not occur to me that they are stuck on instead of off! I am fairly sure that is it. May not get to MN to check it till summer again. Can"t wait till I can get that tractor where I can work on it.
Thanks, again guys.
rgorange
Don L.
01-09-2005 11:33:16
Loosen the brake housings, to make sure the brakes are not stuck. Don L.
John Saeli
01-09-2005 11:11:52
Hey RGORange: All the things you listed are possible. The easiest thing to do is to take the plug out of the bottom of the Tranny Housing & see if is froze in there.
