Slooow Hydraulics - Case 530
yak651
01-09-2005 08:33:39
I have a "67 case 530 (not construction king), first time using it to plow snow. The 3-pt with small blade on the back lifts fine. Front loader is sloooow. I know its a little low on hydraulic oil so will fill that, but will this help or is this how the old loaders work? Or could it be something else? Thanks in advance for the help/ideas!
Lincoln
01-09-2005 11:31:31
 Re: Slooow Hydraulics - Case 530 in reply to yak651, 01-09-2005 08:33:39
The loader on my Case 600 was also very slow. Keeping the oil level full would help some. I finally took the loader off and got a different loader tractor.
John Saeli
01-09-2005 11:17:23
Hey Yak: I'm assuming the loader has 1 way cyl's on it and in no time you pull all the oil out of the resovoir. The pump is only a 12 GPM pump anyway, so it won't set a speed record for loader work. I suggest you overfill it with a mixture of Trans.-Hyd Fluid & 85W140 Gear oil. The gear oil will add body to the thin oil. The warmer your climate, the more 85W140.
