stumped?
Walter
01-08-2005 10:57:23
I have a recently acquired case 500 that is running, however on start up the 2 middle cylinders smoke. The #4 cylinder clears up after 1-2 minutes,the #3 never clears up. The interesting part is (I have the intake and exhaust off) if I cover about 3/4 of the intake the smoke clears up and the cylinder starts firing. The exhaust stays cold until I cover up the intake then it clears up and gets hot. I switched injectors and the same thing happens. Does this sound like a cracked head? I had a valve job done but don't know if they checked for cracks.
Don Rudolph
01-08-2005 17:43:31
 Re: stumped? in reply to Walter, 01-08-2005 10:57:23
If this is a big 500, were the Power cels cleaned when the head work was done? If they are carboned up it will cause trouble.
Vac400
01-08-2005 15:20:46
Walter, Need to know is it white smoke or is it black smoke. You could have 2 different problems. Did you let the tractor get warm and torque the head over again? Do you have bubbles in the radiator?It does not sould like a cracked head. When you take a head to a shop they sould check for that problem.
Jerry
Walter
01-09-2005 15:39:22
 Re: stumped? in reply to Vac400, 01-08-2005 15:20:46
Smoke is bluish white and lots of it,exhaust is cold, no bubbles in radiator. Once again it clears up and exhaust gets hot when I cover 3/4 of the intake. Powercel is clean or at least I can see through it when I have the injector out.
Don Rudolph
01-09-2005 16:00:13
 Re: stumped? in reply to Walter , 01-09-2005 15:39:22
Sorry, I can't help you any further. I just know that non-Case mechanics overlook the Powercels most of the time not knowing how important they are to the combustion process. It sounds like a gas engine needing choke to run. Starving for fuel somehow??
