DC4 tech question
DCM
01-08-2005 10:45:44
I have one that runs well but there is a kind of knocking sound that appears to be coming from behind the belt pulley. Is this something serious and will it get worse with time.I don't work the DC4 just drive it around once in a while.Any thoughts? Dan in AB
John Saeli
01-08-2005 16:16:13
 Re: DC4 tech question in reply to DCM, 01-08-2005 10:45:44
Hey DCM: I wish my experience was like Don's, but it wasn't. My Ring & Pinion went bad. The Ring Gear is on the Pulley Shaft. I had a bushing on the Pinion Shaft go bad & in turn, it ruined the gears. Better check it out & don't run it.
Don Rudolph
01-08-2005 11:22:16
Dan,
You probably have a bad bearing on the belt pulley cross shaft, usually on the opposite end from the pulley. We drove a DC-3 like that for many years. A new one was very easy to put in, however, and by taking one shim out the clanging was completely gone.
DCM
01-08-2005 14:35:24
 Re: DC4 tech question in reply to Don Rudolph, 01-08-2005 11:22:16
Don, would that be behind the 3-corner cast plate. What does a shim removal do to improve the problem. I will check the bearing out and replace if needed.Dan in AB
Don Rudolph
01-08-2005 17:08:20
 Re: DC4 tech question in reply to DCM, 01-08-2005 14:35:24
Yes, that's the place. When I took that bearing out, one-half of the balls were gone (down in the sump). When we put the new bearing in, one shim was left out to keep the clearances right. I agree with John, it should be fixed. Don
DCM
01-08-2005 21:48:37
 Re: DC4 tech question in reply to Don Rudolph, 01-08-2005 17:08:20
Thanks fellas, it will get the attention it needs when when the weather warms a little.The DC4 belonged to the wife's grandfather,so its an important tractor.Dan in AB
