630 puller
Ky Ted
01-06-2005 11:33:05
I have a 1963 case 630 gas narrow front,have never pulled before but looks like fun. Could you guys that know about please help, it needs a ring job and valve work, dont have much money extra to spend so i need to make it count. Is there anything else i can do to help it, also do you think i will have a chanse, dont know what i will be pulling against any help would be great, thanks for the past help.
Jim M
01-09-2005 22:58:39
 Re: 630 puller in reply to Ky Ted, 01-06-2005 11:33:05
Get a set of Case SC wheels and put on it. That will let you use 38" rubber. Sc wheels are 2 5/8" bore. 630 should be 2 1/2". Use exhaust or driveshaft tubing to make tham fit.
Goldie
01-06-2005 14:41:03
A 630 is a very good puller. We pull one with a triple range transmission and a wide front. We pull 5000&5500 any exra wieght goes on the back. Never had the front end off the ground. As for your motor try to find 600 combine w/ 201 gas motor. They are about 60 hp and you can find them for $200 to $300. Good luck!
