Case 1737 Uniloader
Dave Strnad
01-04-2005 20:22:23
I just purchased a case 1737 uniloader and I was wondering if anyone had any idea what type of fluid it uses, it appears that the fluid is held between the wheels with the clutches and drive chains, so would I just use tractor hydrolic fluid? and how high should it be filled I noticed two small plugs just below the plate and one large plug above the plate, should the clutches be submerged? Also does anyone know of any good sites that might be of help, or that post part break downs on-line?
Thank you for any help
Dave
Tom (Ks)
01-05-2005 16:38:42
 Re: Case 1737 Uniloader in reply to Dave Strnad, 01-04-2005 20:22:23
It's been a long time since I worked on them, but it uses automatic transmission fluid in the wheel area. the small pipe plugs are "full" and "low" if I remember.
