Trying to get 990 serviced, it sat idle for over a
Ruston
01-04-2005 11:42:54
My Case David Brown 990 sat up for over a year. I got it cranked the other day.
The lift is now very sluggish. Regardless of the lift lever position, high idle raises the lift and low idle lowers it. But later, for whatever reason, nothing will really raise the lift. Then later, maybe it will raise very slow and lower a time or two with the lift lever.
I would like to drain all the oils and change all the filters on the tractor. I thought I WAS adding hydraulic oil to help the lift, but maybe not:
To the right of the gear shift is a dip stick. I think that is gear oil. It is milky in color, but at the right height on the dipstick. Is white color is sign of water?
I tried to add hydraulic oil to maybe help the lift. I removed a bolt to the left of the seat and added oil. That raised the level of the milky oil on the dip stick to the right of the gear shift. I thought the add oil hole for the gears was to the left of the gear shifts. Maybe I have to much oil and it overflowed.
Where do you add the hydraulic oil? I have the owner"s manual, but not all the pictures look right.
Thank you very much.
Ritchie Leslie
01-07-2005 09:17:34
 Re: Trying to get 990 serviced, it sat idle for ov in reply to Ruston, 01-04-2005 11:42:54
Hi, I'd say for sure that you need to change the oil and filter. There are two drain plugs for the hydraulic/transmission oil - one on the round filter housing right under the transmission - and one further back just in front of the PTO. I suggest you replace the filter too, given all the water. The filters and gaskets can be ordered from any CaseIH dealer.
I use the standard hydraulic/transmission fluid available from any tractor dealership in my 990. It takes over a full bucket so be warned!
The filler is a flat plug on the top of the gearbox close to the shifters. There is a special too available to remove it as it has some funny British dimension that does not really take a standard socket driver properly. The same tool will allow you to easily remove the filler plugs in the final drive transmissions - suggest you change the heavy gear oil in these puppies at the same time.
And completely agree with the comment about replacing the rubber gearshift boots. Rain is the worst enemy of the DB hydraulic system and if you can't keep the unit under cover I suggest you keep a tarp over the rear half of the tractor at all times.
Hope this helps, another DB 990 owner.
Eddie in Ky
01-04-2005 18:30:37
Best advice I can give, and I have had an 885 for 3 years now, get a manual. Read it, then go from there. Yes milky is water, sounds like you added to the right hole. You will want to change hydraulic filter and all probably, I did when it had milky fluid, and helped a bunch. But seriously, get a manual, it'll save you a lot of headaches. Oh yeah, check you gear shift rubber boots, if they are cracked, replace them, that's the best place for water to get in tranny.
Ruston
01-05-2005 07:53:02
 Re: Trying to get 990 serviced, it sat idle for ov in reply to Eddie in Ky, 01-04-2005 18:30:37
Thanks Eddie in Kentucky. Yes, my gear shift rubber boots are in terrible shape.
I am going to order a manual off this site. There are several for the 990. Do you recommend one in particular? I like the description and price of C-203, I&T Aftermarket Shop Repair Manual, $29.95. But I will have to check my serial number first. Where is it located?
Of course, there is the (official) Service Manual CA-S-770ETC DB for $59.95 which probably covers all 990s, I would guess. Thanks again for your help.
Harvey in Louisiana
S�ren DY
01-18-2005 20:09:27
 Re: Trying to get 990 serviced, it sat idle for ov in reply to Ruston, 01-05-2005 07:53:02
Your serial number is located on the upper side of the frame just tho the right of the radiator.
S�ren DY
Eddie in Ky
01-06-2005 15:32:20
The I&T manual is what I have. It has served me well
