another question for dctom
Ken in Canada
01-03-2005 20:04:30
Thanks again for the information on my Case DC. I also have a second DC. Could you also give me information on it? The serial number is: 5318070DC. Do DCs from this year have wet clutches? Thanks again. Ken
dctom
01-05-2005 07:06:13
 Re: another question for dctom in reply to Ken in Canada, 01-03-2005 20:04:30
ken, 5318070 DC-4 built april 5 1949 shipped to j i case co. ottowa, ont can april 6 1949 Yes all DC's have wet clutch, make sure you drain oil out of clutch houseing when you change oil, no need to put any back in there as it gets it from the engine tm
Ken in Canada
01-05-2005 15:27:09
 Re: another question for dctom in reply to dctom, 01-05-2005 07:06:13
What does it mean if my wet clutch is dry? What would the reason be for the oil not be delivered from the engine? Thanks again for the information. I have 2 case dcs that have the same problem. Ken
dctom
01-05-2005 16:02:43
 Re: another question for dctom in reply to Ken in Canada, 01-05-2005 15:27:09
KEN; NO OIL AT ALL IN THE CLUTCH HOUSEING?? NEVER HEARD OF SUCH A THING BUT IF THERE IS NONE THAN THE HOLE IN THE END OF CRANK SHAFT WITH THE METERING PLUG IS FULL OF CRAP AND PLUGED, MEANS SPLITTING THE TRACTOR REMOVE FLY WHEEL AND CHECK HOLE AND METERING PLUG, ONLY THING I CAN THINK OF TOM
fredct
01-05-2005 18:45:58
 Re: another question for dctom in reply to dctom, 01-05-2005 16:02:43
Tom, if the DC is anything like teh SC can"t he just pull the oil pan to check the opening from the crank case to the clutch? I know I can on the SC. FSB
Ken in Canada
01-05-2005 18:25:56
Thanks again for all your information. Ken
