1070 case
patrick conner
01-03-2005 15:28:32
i'm thinking about purchasing a 1070 that appears to be in somewhat good condition however it does show some wear & has some control knobs & hydrolic cable problems that I think can be taken care with little problem. When I test drove the tractor, the clutch did not engage until the cluch pedle was to the top. does anyone know if that is normal?
Is there anything that I should be looking for that might be a sign of problems? I am not a farmer and will use the tractor to pull a 7 or 8 ft. disc and possibly a roller chopper to cut brush & small trees.
pat conner
nb
01-04-2005 06:18:01
 Re: 1070 case in reply to patrick conner, 01-03-2005 15:28:32
You may need to adjust the linkage alittle on the clutch. Powershift models usually engage close to the top. They have hydraulic clutch in them. They usually trouble free tractors. At 110 hp., you will have plenty of power to pull that 8 ft disk!
leland
01-04-2005 23:46:35
 Re: 1070 case in reply to nb , 01-04-2005 06:18:01
8' disk you should be able to drag it in road gear, and make sure tranny is in 1st range when backing these things go fast in reverse.
