Case VC
Ted Haag
01-03-2005 14:50:00
New to this. My 1941 Case VC locked up. Starts and runs w/ clutch in but stops as if under load when in neutral w/ clutch let out. Will not move when in gear. Couple of "clinks" B4 it locked up. Tranny looks OK. No squealing w/ clutch in. Gotta be something in the drive shaft. Any ideas as to where I should start on a repair?
Klyde
01-03-2005 16:37:33
 Re: Case VC in reply to Ted Haag, 01-03-2005 14:50:00
Pull the shifter cover first and make sure the shifter forks are in the right place. Also if its freezing where you are and there is water in the oil that may be doing it.
Ted Haag
01-06-2005 11:06:14
 Re: Case VC in reply to Klyde, 01-03-2005 16:37:33
Had pulled off the top of the tranny. Forks are where they should be. Problems gotta be behind the clutch and forward of the tranny. Did I mention that it locked up after running it for a mile and a half? Yes, it"s been cold---if ice is doing it it"s gotta be a pretty large piece.
