case sc
nation brimm
01-03-2005 06:17:43
How many horsepower is an sc? This is the first case I've ever messed with. Thanks
C. Amick
01-03-2005 07:42:35
 Re: case sc in reply to nation brimm, 01-03-2005 06:17:43
It's about the equivalent of a Farmall "H", only better.:) The first ones built were around 23 horsepower with the 3-1/2 inch cast iron pistons. Case put 3-5/8 inch pistons in the later models. There were also 3-11/16 inch aluminum button topped aftermarket pistons available which brought the horsepower up to around 30.
todd hamilton
01-03-2005 07:39:48
Stock HP ratings range from 18 - 22 HP depending on vintage, size of pistons, which documentation you are reading, etc. A somewhat common practice to boost horsepower on Case gasoline engines was to install an LP head to boost compression.
nation brimm
01-03-2005 08:12:19
 Re: case sc in reply to todd hamilton, 01-03-2005 07:39:48
Thanks for your quick replies. Now that gives me an idea of what I'm working with.
Grapefarmer
01-03-2005 08:35:03
 Re: case sc in reply to nation brimm, 01-03-2005 08:12:19
LOL!!
Around 25 - 28Hp should be a good guess.
-Dave
