441 or 430 case
Joe Marez
01-03-2005 03:46:32
can any one tell me what the hp is on a 441 or 430 case are they pretty much the same tractor & can you put a wide front end on a 441 that has a narrow one thank 4 your time
Dennis/Ohio
01-04-2005 02:38:57
 Re: 441 or 430 case in reply to Joe Marez, 01-03-2005 03:46:32
I'll guess 36HP
The 441 general purpose would be a adjustable wide front.
430 Utility would be heavy duty front axle and tractor lower to the ground. You would also need the final drive that would set the rear lower to the ground.
I wouldn't try either unless I could find a parts tractor with all the hardware I needed.
Best Wishes, Dennis..... ...
