430 clutch
Mike Schwartz
01-02-2005 21:10:48
I was able to get the 430 running today, runs well but I think the clutch is out. I do not have the books yet so can anyone explain how the foot clutch and hand clutch work together? Hand clutch still snaps over center. Foot clutch has free play on top. Throwout bearing talking a little with clutch depressed. Working the clutch pedal, the clutch will try to grab but will barely move the tractor around, any ideas? Is this a dry clutch or oil bath like the SC's? Tractor is a Diesel triple range if that makes any difference. Thanks MIkeS (WA)
Dennis/Ohio
01-04-2005 02:49:36
 Re: 430 clutch in reply to Mike Schwartz, 01-02-2005 21:10:48
The early 430's had the throw-out bearing installed backwards from what I was used to seeing around trucks. Coil spring keeps the bearing against the pressure plate fingers and it spins with the pressure plate. (I think I said that right).
Best Wishes, Dennis..... .
mEl
01-03-2005 05:48:38
Mike, the 430 uses a dry clutch, if it is an early tractor watch for clearance issues at the timing pin boss with a newer style pressure plate, grind as necessary to allow p-plate to turn through. Please do yourself a favor , use OEM parts as the most popular aftermarket suppliers stuff don"t cut it in this mans opinion, If flywheel shows any wear, have it faced but if a lot is taken off make sure p-plate capscrews are not bottoming. mEl
