Case parts cross refence Case 500
Glenn/Mn
01-02-2005 12:45:14
Need two gaskets for around the engine thermostat, case says discontinued I dont believe them, so can someone look up the new part numbers, these are metal gaskets for high heat, otherwise I could just make them.
A7639
09807AB
John Saeli
01-02-2005 13:42:18
 Re: Case parts cross refence Case 500 in reply to Glenn/Mn, 01-02-2005 12:45:14
Hey Glenn: A7639 doesn't appear in an '89 Price Book I have. All the engine kits today supply a heavy paper, or grey cardboard type gasket. That water manifold doesn't get so hot that it will destroy paper.
Camboted
01-02-2005 16:03:38
 Re: Case parts cross refence Case 500 in reply to John Saeli, 01-02-2005 13:42:18
You can "cheat" with some high temperature silicone.
Glenn/Mn
01-02-2005 16:36:12
 Re: Case parts cross refence Case 500 in reply to Camboted, 01-02-2005 16:03:38
Thanks for the help, I will try the dealer once more, they had the water pump seal and I finaly got that the impellar repressed back on saturday, may have to try Olson Gasket, I believe thats their name, and they are somewhere out west, I will have one more question later on about the pulley as that part comes around, Say John anyone making reproduction Vacuum gauges for the diesels
John Saeli
01-02-2005 18:34:06
 Re: Case parts cross refence Case 500 in reply to Glenn/Mn, 01-02-2005 16:36:12
Hey Glenn: I am actively pursuing guages. Vacuum guages are a priority.
Pat T
01-03-2005 03:19:03
 Re: Case parts cross refence Case 500 in reply to John Saeli, 01-02-2005 18:34:06
John-
Please e-mail me when you are up and running with the vacuum & pressure gauges. I consider myself on your waiting list!
Pat
Glenn/Mn
01-03-2005 18:15:46
 Re: Case parts cross refence Case 500 in reply to Pat T, 01-03-2005 03:19:03
You can add me to the list as well
