NEEDED: Clutch/pinion Shaft and Brg. 1936 CASE L
D. Hilman
01-02-2005 10:13:20
I just finished dimantling the tractor from front to rear to see what I needed for parts and feel quite lucky. The only parts I need are the pinion that has 4 teeth pitted quite bad from rust, and the pinion brg. which is worn out and has turned on the shaft. Can someone point me in the direction of these parts?
leland
01-02-2005 21:50:43
 Re: NEEDED: Clutch/pinion Shaft and Brg. 1936 CASE in reply to D. Hilman, 01-02-2005 10:13:20
I have saw that [email protected] sells old case parts
John Saeli
01-02-2005 13:14:05
Hey D Hilman: Someone will jump in & help, but you will need to replace the Pinion & Ring Gear. They are always furnished as a matched set.
D. Hilman
01-02-2005 19:36:13
 Re: NEEDED: Clutch/pinion Shaft and Brg. 1936 CASE in reply to John Saeli, 01-02-2005 13:14:05
Thanks for the reply John. I realize that crown and pinions are replaced as a set, but in this case the crown (ring gear) is in good shape. I was hoping that someone may have a good pinion, with a brg, that came from a tractor that had a damaged crown. I expect an unmatched set to make a bit of noise, but for a half dozen tractor pulls per year I can handle a little noise.
Of course I will take a set if need be.
