Case 530
BigDiesel
01-02-2005 06:01:22
need an engine for my 530 gas tractor, rod went through the block. any place you guys know thats reasonable? thanks for the help.
Dennis/Ohio
01-04-2005 03:03:43
 Re: Case 530 in reply to BigDiesel, 01-02-2005 06:01:22
I have two early blocks with the bolt-on oil filter. I'm running the later block with filter cast on the block. I went on a buying spree thinking I'll blow an engine someday. Probably won't happen so.....
I'm in Akron 44312. [email protected]
Best Wishes, Dennis..... ..
Lincoln
01-02-2005 16:35:33
Does the 530 use the same engine as the 611B? I think there are a couple of 611s being parted out on ebay, havent seen an engine listed yet.
