Case 430
Mike Schwartz
01-01-2005 20:29:22
Hello, Went and picked up a case 430 from a friend today. It is a low profile(utility?) tractor with a diesel engine. Cannot seem to find serial number listing for it on site. The number is 430L 6171912 . Hard to tell in the dark and the snow but it looks like it has triple range tranny, power steering, hand clutch, not sure if it is actuall three point or a modified eagle hitch. Engine not running(fuel problem). Can any one help with year of tractor or engine size so I can order books? Any known weak spots or advantages? Will be the newest tractor in the fleet but I am thinking it is still at least 40 years old. Thanks Mike S(WA)
Mike Schwartz
01-02-2005 11:08:35
 Re: Case 430 in reply to Mike Schwartz, 01-01-2005 20:29:22
Thanks Gene, Joe, and JRT for the info. Interesting to find out about the Rock Island/ Racine differences. I was stumped when I was not able to find a serial number match on this sight, even went back out to double check the first digit. It sure looks like it will be a handy little tractor when I get it running. From looking in the archives it appears that the L after the 430 designates low speed gearing, does this sound right? Thanks Mike(WA)
Gene Dotson
01-02-2005 03:21:59
Mike, the tractor is indeed a 1961 model. The early production "430's were built in Rock Island from 1960 into 1963. In 1963 the production was moved to Racine with the bigger tractors. Rock Island started using the 6 million numbers in 1953 while Racine started using 8 million numbers at the same time. When production moved to Racine they started using the Racine 8 million numbers. Interesting change here is battery system ground. All Racine built tractors used negative ground systems and all Rock Island tractors had positive ground system... Gene
Joe (Wa)
01-01-2005 22:29:56
Could the first digit in that serial nr be an 8? That would make it 1961. I don't see any 430 s/n starting with a 6 only 3 & 8.
Joe
Joe (Wa)
01-01-2005 22:56:23
 Re: Case 430 in reply to Joe (Wa), 01-01-2005 22:29:56
Well now that I have looked around some, that first digit could be a 6. If you check the Tractor Registry on the left there are two 430's with first digit 6. Also check the link.
Joe
JRT
01-01-2005 21:23:18
That 430 model is probably somewhere in the early 60's. Seems like the late 60's models had an 8 speed transmission with a standard hitch. The enging is a 188 cu. in. and a great little engine. I have had a 430 diesel I have used a good amount over the past 10 years and with the exception of the fan breaking and demolishing the radiator, I have had no problems with it. Check your fan blades for cracks. Those radiators are hard to come by.
