Lift Cylinder
JDB
01-10-2006 06:07:38
E-bay has an eagle hitch lift cylinder. Anyone here bidding on it? If you are, I won't. What is a fair price for one?
JDB
01-11-2006 06:36:42
 Re: Lift Cylinder in reply to JDB, 01-10-2006 06:07:38
Thanks guys
charley hellickson
01-10-2006 17:27:49
hi guys. i just checked out that cylinder and it is the rear mounted lift cylinder for a DC or SC with hydraulic. for lifting the cultivator,ect. my 48 DC has one. it is a one way cylinder. charley.
Camboted
01-10-2006 14:19:05
I can't tell if it is an eagle hitch cylinder or a cylinder from the 49-51 DC's. They are slightly different. I priced an Eagle Hitch cylinder at Meyers-Ward near Fresno, CA. They wanted $50.00, so that should give you an idea.
mj
01-10-2006 09:56:49
Looks like you can buy it for a bit over his starting bid which would be a half or third of what I'd want for one of mine..... .....they are like land..... ...not makin' any more of them.
Mathias NY
01-10-2006 11:46:59
 Re: Lift Cylinder in reply to mj, 01-10-2006 09:56:49
Do you know the specifications of the cylinder? I don't own one, but need to aquire one this spring.
I can buy a brand new welded (no tierods) cylinder, 12" stroke, 2-1/2" bore, 1-1/4" rod, with a 3000 psi rating for about $150. I already own a can of Flambeau spray paint...
Camboted
01-10-2006 14:22:56
 Re: Lift Cylinder in reply to Mathias NY, 01-10-2006 11:46:59
That won't work. The eagle hitch cylinder is designed to operate as a single action, 6" stroke and I believe a 4" bore. If youput a smaller diameter cylinder on it you will have no lifting power and if you go with a longer stroke your hitch will not go low enough.
Mathias NY
01-10-2006 17:10:58
 Re: Lift Cylinder in reply to Camboted, 01-10-2006 14:22:56
Thanks for the information.
I don't currently have an Eagle Hitch, but I do have the hydraulic pump and am considering building a 3 point hitch instead. I need to buy a remote cylinder anyway for some towed equipment and was hoping I could use the cylinder.
Incidentally a new cylinder with 4" bore and 6" stroke is about the same price.
DKase
01-11-2006 05:55:05
 Re: Lift Cylinder in reply to Mathias NY, 01-10-2006 17:10:58
For remote equipment you need an 8" stroke! DK
