New To Case
HCompton
01-01-2005 12:58:38
I have restored 3 Ford Ns now I am wanting to restore a 1 row tractor. Did Case ever make 1 row tractors , if so what were their model numbers?
JGarner
01-04-2005 12:06:06
 Re: New To Case in reply to HCompton, 01-01-2005 12:58:38
The VAC and SC are both considered one row tractors, the DC is a 2 row. The SC is a much larger tractor and was marketed by Case as a heavy duty one row.
A row is considered as how many furrows or "beds" a tractor can make pulling buster (bedding) plows. I see some folks on this site confusing "row" with "bottom" a bottom is a molboard or disc type turning plow. The VAC will pull a two bottom plow, the SC will pull 3 both on level ground.
Brian in Ohio
01-02-2005 05:44:51
Don't know how OLD you're wanting to go, but you might want to think about a RC. Not as common as a VA Series, handle 1 plow easy, and makes a good restotation project.
IMHO
Joe Blahitka
01-01-2005 16:02:22
Case Model 300 Series tractors: Model 312 gasoline single front wheel. Good luck finding one. Joe
HCompton
01-01-2005 17:30:28
 Re: New To Case in reply to Joe Blahitka, 01-01-2005 16:02:22
Thanks for the help, but I am puzzled here. Joe how can a 1 wheel tractor be a 1 row tractor? You would be running over everything that you were plowing.
Gene Dotson
01-01-2005 15:54:46
Yes, Case made the Model VAS for one row and specialized cultivating... Gene
Joe Blahitka
01-01-2005 18:36:09
 Re: New To Case in reply to Gene Dotson, 01-01-2005 15:54:46
Hi Gene: I guess I am confused. I misunderstood and thought he was asking about a one wheel Case tractor. What is a one row tractor model VAS? If you know where I can see a picture please let me know. Thanks. Joe
Gene Dotson
01-01-2005 19:27:46
 Re: New To Case in reply to Joe Blahitka, 01-01-2005 18:36:09
third party image
Joe, the VAS was a high profile, narrow tread with operator offset to the right, like the farmall A. Went to the vintage ads and typed in VAS and brought up 7 photos. If the link works, it shows a VAS that was sold... Gene
Gene Dotson
01-01-2005 19:24:30
joe blahitka
01-02-2005 07:16:49
 Re: New To Case in reply to Gene Dotson, 01-01-2005 19:24:30
Thanks Gene. Now I know what a Case VAS is! Joe
