DC hood latches
Sean M
01-01-2005 12:42:49
Does anyone know where I can find some hood latches for my DC hood. The hood is in good shape, but none of the latches work.
Thanks
L.Lamp
01-01-2005 13:30:21
 Re: DC hood latches in reply to Sean M, 01-01-2005 12:42:49
There were no hood latches on the DC models. Use the appropriate 3/8" bolt that will do the job. I use bolts on the front and short pieces of redi bolt on the back. I screw the pieces into the threaded inserts on the hood and put a washer and nut on where they go through the gas tank bracket. You might want to run a tap in the threaded inserts in the back to clean out the rust and other accumulated material.
Sean M
01-01-2005 20:20:25
 Re: DC hood latches in reply to L.Lamp, 01-01-2005 13:30:21
Thanks,
I thought when I got the hood it had remnants of an overcenter latch. I'll look at it tomorrow. If I remember right there are no bolt holes in the hood. Thanks again.
