VAC transmission
Scott KY
12-31-2004 14:26:57
Brought home a VAC couple weeks ago. Previous owner said it had transmission problems. I pulled the top off and discovered the oil slinger gear teeth completely chewed off. What would cause this?
Ron in mid MO
01-02-2005 07:40:12
 Re: VAC transmission in reply to Scott KY, 12-31-2004 14:26:57
I have a 1950 that I have had about a 1 1/2 years. The same thing is wrong on mine. What I had came up with was the "plug - interlock" had worn the indent on the "rod shaft" that holds the fork. Was letting one gear stay in one gear while the other went in another. Built my rod shafts up with a welder and seams to be workig for me.
