Solid state voltage regulator for a generator
markloff
12-30-2004 19:07:07
Hello,
In my experience the item that usually goes bad in a generator system is the voltage regulator. I was wondering if it would be possible to wire in a solid state voltage regulator from an alternator? It could all be enclosed in the original voltage regulator box for a 100% stock appearing tractor. Often the hardest part of an alternator conversion is mounting the alternator itself. This of coure would eliminate this also. I checked on pricing for a Delco alternator an you can get a voltage regulator for under 10 bucks new. Also other systems have external voltage regulators. Would this work? How can it be done?
