730 diesel heads
PatO
12-30-2004 18:04:23
I have an early model 730 - eagle hitch w/ older style guages w/ two cracked heads and decompressor - got it started tonight- but had a lot of smoke coming out of the radiator - knew it had cracked heads but wanted to be sure it was runnable before putting any MORE money into it - does anybody know of any reasonable place to get heads that aren't cracked - can redo valves and the rest - looking for something that will just keep the water out and is reasonable/cheap -in NW Iowa - any help appreciated - THANKS!!!
Roger H
12-30-2004 20:26:34
 Re: 730 diesel heads in reply to PatO, 12-30-2004 18:04:23
Pat, if you can't find different heads, take those to Midwest Cylinder Head in Nevada Iowa to have them welded. If you call them, have the casting number handy & they can give you a price, probably $200+ per head but they do excellent work, had them do 2 of 3 heads from a 930 LP & no problems so far.
