530 Case
Mike Hughes
12-30-2004 17:07:33
The 530 is a puzzle to me. I have one,It has a model#31 loader and hoe on it. What is the diffrence in a 530, 530B, 530CK, mine has a grille like a 630, it has a non adjustable tread width, and a heavy front axle with power steering which has a shaft running into a steering box under the radiator and a hydraulic steering cyl in the tie rod. A gas eng is the power source, of what C.I? also what is the diffrence in a 310and a 530 besides year? where can I learn more about these AWESOME MACHINES?Mike~~
Dennis/Ohio
12-31-2004 03:21:55
 Re: 530 Case in reply to Mike Hughes, 12-30-2004 17:07:33
Hi Mike,
You'll find an endless amount of info in the archives. Mine is same as yours. I'll try to add a link so you can see it.
Its not original but it does work like a new unit. I used what would work at the best price. best, Dennis....
BKahler
12-30-2004 19:05:10
Hi Mike,
I can answer at least one of your questions. The 530CK had the model 32 loader and model 32 backhoe. I've made the assumption that the model 31 is a somewhat lighter and/or slightly older version of the 32.
My 530CK has the 188 diesel and if yours is gas is probably a 159 CI engine. My tractor model number is D530B and was made in 1963.
I'm in the process of rebuilding the engine as it spun a rod bearing before I bought it. Seems to be a nice unit. Can't wait to use it!
Brad
Dennis/Ohio
12-31-2004 03:08:36
 Re: 530 Case in reply to BKahler, 12-30-2004 19:05:10
Hi Brad,
Had a tractor guy tell me the most spun rod bearing are on old hoes because the operaters back is to the gauges. I added a large oil light to my hoe controls. Thought you might like that idea?
Ps....Don"t forget the crawler forum. That forum seems to have more "diggers" where as this forum seems to have more collectors.
Best wishes, Dennis.....
mike Hu
12-31-2004 18:03:25
 Re: 530 Case in reply to Dennis/Ohio, 12-31-2004 03:08:36
Nice machine Dennis!
