VAC steering adjustment???
Keith-OR
12-29-2004 21:12:25
I need to know what the play in the steering wheel is normal for a VAC. Have made all the adjustments that the manual calls for, even rotated the worm wheel, still have about 3 or 4 inches of movement in the wheel before pitman arm starts to move. Is this about right or do I need to remove the steering the steering assembly to do some more adjustments???..... .Thanks
Keith
Keith-OR
12-30-2004 12:27:36
 Re: VAC steering adjustment??? in reply to Keith-OR, 12-29-2004 21:12:25
Thanks both Mike and John for your input. Mike the movement is in the steering sececter, there is no movement of the steering arm (Pitman arm). I have a parts tractor, which I pulled the steering unit off of it. There was some slack in the worm gear, removed cotter pin from the crown nut and tighten nut up, still has slack in the wheel, rotated the worm wheel over.All adjustments has removed a lot of the slack in wheel movement. Will use this steering on mine. Also will check out one on my tractor after I get it off. Probably same problem with it. Again thanks for your great suggestion and input..
Keith in Gods country.
John LeMay
12-30-2004 05:44:16
That is about what my dad has on his VAC - maybe 10-15 degrees, about 3 inches I'd say measured at the outside of hte steering wheel.
mikefromiowa
12-30-2004 05:42:10
Where is the slack coming from? when you move the steering wheel, does the arm coming out of the gear box move with the wheel? there is an adjustment for the mesh of the gear box. Not sure what else would be adjustable.
