D530B CLUTCH JOB GONE !!!!!!!!!!!!
TIGGER
12-29-2004 17:15:48
This is the second clutch job I have done and it"s from hell.New clutch,pressure plate, pilot bearing,throw out bearing.Assembled all parts, bolted tractor up, NO CLUTCH PEDAL AT ALL.Took apart, set fingers up, now pedal, but won"t release. Bearings all ok, adjusted linkage ,all ok parts, all seem to be ok. ALSO SURFACED FLY WHEEL, TRIED OTHER THINGS. THIS WILL BE THE 4TH TIME SPLITTING THIS TRACTOR.????? ?????
just Roy
12-29-2004 19:35:23
 Re: D530B CLUTCH JOB GONE !!!!!!!!!!!! in reply to TIGGER, 12-29-2004 17:15:48
Sounds like you have the clutch plate in backwards
