Case 530 diesel=any suggistions
Jrry
12-29-2004 06:08:37
I have a case 530 diesel that I can't get cranked. I bought the tractor and the injector pump was in a box. I purchased a working pump and installed. I timed the tractor. Fuel is getting the block because the number one injector is leaking a little and I checked the no. 2 injector. The tractor has good compression and the engine turns over good with the starter. Smoke comes out the exhaust, I rechecked the timing on the gears attached to the pump and the marks are lined up correctly. The two marks on the window in the pump are lined up. However the pointer is missing on the timing gear in the transmission. I;ve tried spraying either in the intake but that makes the engine slow down when I try to crank. The tractor does not fire at all. It seems that if smoke is coming out the exhaust and the timing is correct the tractor should run providing there is compression which it has. I'm not very famalier with diesels and would appreciate any guidance.
merv
01-11-2005 19:08:48
 Re: Case 530 diesel=any suggistions in reply to Jrry, 12-29-2004 06:08:37
What colour is the "smoke" ??. White = unburnt fuel vapour; timing is out; try moving pump while cranking. Black = too much fuel.
Ky Ted
12-29-2004 15:42:01
Check and make sure your kill switch is not pulled out.
will in Tx./Mn./ USA
12-29-2004 08:20:58
Pointer missing on the transmission?.. i don't follow, but i do advise you to STOP USING THE ETHER!
~Will
Just Roy
12-29-2004 06:59:44
Check and make sure that you do not have it 180 degrees out of time. Both lines will line up 180 out and it will not start as it will be injecting fuel on the ex stroke instead of compression
Tom (Ks)
12-29-2004 18:44:22
 Re: Case 530 diesel=any suggistions in reply to Just Roy, 12-29-2004 06:59:44
I have seen the air cleaners so pluged that the engine can't get any air.
Doc Larry
12-29-2004 18:56:12
 Re: Case 530 diesel=any suggistions in reply to Tom (Ks), 12-29-2004 18:44:22
Just Roy...
The engine should at least attempt to fire with ether. Apparently it didn"t, if so, I"d leave the fuel system alone and check Tom"s air cleaner idea - or any other serious restriction in the air intake - dead rat, bird"s nest, whatever....
Next I"d look for a compression problem or valve timing problem.
Good luck....
Larry
