Crossmotor Case Airwasher?
Bobcat
12-28-2004 18:52:19
Does anyone know if somebody is making reproduction Airwashers for any of the old crossmotors? Do models 12-20,15-27,18-32 use the same one? I know finding a used one is pretty much impossible. Thanks!
Bobcat
12-29-2004 10:04:20
 Re: Crossmotor Case Airwasher? in reply to Bobcat, 12-28-2004 18:52:19
I would like to thank you all for your many E-mails and great advice on this! I have one located and am ready to go after it! Thanks Again! Bobcat
Glenn/Mn
12-29-2004 06:08:10
There are some simularities between the two but then there are differences for example the float valve is different size between the two, the latch parts are the same and so are the top and bottom casted parts, but the physical size is different between the to, I am not sure if their exists any great deal of difference between the 15-27 and the 18-32, if it did it would have to be on the very early 15-27 as there are differences in the oil line piping for lubrication I called the same place was not impressed with the answer to my questions so I passed may try to remake my own, I have both sitting in the porch right know.
C. Amick
12-29-2004 05:28:21
Try Buchert Farms 217-847-2690 or 2874 or [email protected]
