Case L steel wheel color
Steve (DE)
12-27-2004 15:24:42
I know the wheels on the L were Case Red, but in poring over several of the 1930's Case sales brochures, I noticed that the illustrations (color drawings, not photos) show the rear wheel lugs and the front wheel skid rings as grey (or at least the same color as the rest of the tractor). Has anybody ever actually seen any original wheels or color photos of this? And, by the way..Happy New Year to all.
Glenn/Mn
12-27-2004 16:12:12
 Re: Case L steel wheel color in reply to Steve (DE), 12-27-2004 15:24:42
I believe that in many cases this was a artists impression as to what looks and or sells best in a catalog, tractors were assembly line painted by this time and they didnt stop to paint the lugs a different color most lugs were shipped loose and were put on the the dealers themselves as far as the smaller tractors many of the larger engines were Riveted on from the factory, maybe they never waisted the time to paint them if the paint was going to come off any way, and the gray feature was that of a new formed lug and not paint, just a thought
Steve (DE)
12-27-2004 18:21:45
 Re: Case L steel wheel color in reply to Glenn/Mn, 12-27-2004 16:12:12
I had thought that since the tractors were shipped without any lugs or grouters on the wheels, that just the wheels would have been red. Since the Case Manuals all say that the lugs, grouters, etc. were to be put on when the tractor was prepared for delivery, or actually received, by the customer, they might well have just been raw steel. I further assumed that most guys in repainting their tractors wouldn't be going to the bother of removing the lugs just to get that extra bit of "authenticity". Since I have to replace about 1/3 of my lugs, I may just take them all off, paint the wheels red with a 2-part epoxy, and then bolt all the lugs on. Give me something to jaw about at the shows.
Dr Cy Kosis
12-27-2004 20:20:13
 Re: Case L steel wheel color in reply to Steve (DE), 12-27-2004 18:21:45
Have fun taking them off. I recently removed the sand lugs from my '29 L. The first side went ok with liberal amounts of PB Blaster, a HD socket, a long breaker bar and an impact gun.
The other side wasn't so easy. After two days, and a burnt up air compressor, I got all but about 8 bolts out before resorting to the "hot wrench" to finish it up. I guess it wasn't too bad as I actually thought I may have to cut them all after 75 years in the dirt.
Almost all the lockwashers shatterd on removal but all but the cut bolts and nuts will be rusable. I don't know where I'll ever find the large square headed bolts to replace the cut ones should I ever decide to put the lugs back on.
I hated to take the steel off but I didn't want to refloor the trailer again.
Eugene Kinzel
01-09-2005 09:43:35
 Re: Case L steel wheel color in reply to Dr Cy Kosis, 12-27-2004 20:20:13
I'm restoring a 1930 L, any idea where I can get the front steel wheels, magneto, intake-exhaust manifold with the pre heater box for a Kingston carb, and a good gas tank double compartment. Any help would be appreciated, thanks.
Steve (DE)
12-27-2004 21:18:01
I have a place in Philadelphia that has the square head bolts to put the lugs on the wheels. I don't remember the price, but it wasn't outrageous, and I'll be there in about two weeks to get a whole bunch more for my own wheels. Let me know if you're interested.
Glenn/Mn
12-27-2004 19:15:31
Just curious have you found replacement lugs or know of anybody making replacements, looking for a set on my 30 C. I have spent time looking at them just have not come up with any ideas if they were forged or poured
Steve (DE)
12-27-2004 21:24:03
 Re: Case L steel wheel color in reply to Glenn/Mn, 12-27-2004 19:15:31
I don't know of anybody making new lugs. I got mine as extra along with the wheels, because some of the ones on the wheels were all beat up. The "extra" were off other old wheels. I expect that if enough guys got together to buy lugs, and had one original good lug as a pattern, getting some small foundry to cast them wouldn't be all that difficult. It really shouldn't take that many guys to be wanting, say, a total of a hundred or so of the lugs. It probably wouldn't cost much more than the time or cost of weld/building up the old worn out ones and then grinding them back to correct form, which is what I hear that many guys do.
