case400
ontfarmboy
12-26-2004 06:11:19
is it possibleto add hydraulics and Eagle hitch to a standard 400?
caseman-d
12-26-2004 15:58:49
 Re: case400 in reply to ontfarmboy, 12-26-2004 06:11:19
The 400 should already have hydraulics. The eagle hitch can be added depending how bad you want it. You would have to do a lot of fabricating, maybe removal of the fenders, and not to mention crawling over it to get on. Why not just trade it for one that is equipped with one ?????
caseman-d
neale
12-26-2004 18:28:21
 Re: case400 in reply to caseman-d, 12-26-2004 15:58:49
Yes it is possible--You may have to split the tractor to install the pump shaft drive bushing to the flywheel.The eagle hitch arms may touch the ground if you tractor has original tire size. I would be interested in the flat back and I have all parts for the hyd install---Neale
ontfarmboy
12-27-2004 14:45:33
 Re: case400 in reply to neale , 12-26-2004 18:28:21
We are interestedin selling this tractor,it has all new rubber,very good paint and new rubber.Our location is halfway between Ottawa and Toronto,20 minutes north of the 401.
