How is it to find a magneto for a Case C or L?
Nicholaus Sowde
12-25-2004 11:55:48
How is it to find a magneto for a Case C or L? Thanks
DrCyKosis
12-25-2004 14:45:02
 Re: How is it to find a magneto for a Case C or L? in reply to Nicholaus Sowder, 12-25-2004 11:55:48
It depends on whether your wanting the correct magneto for the model/year, or, if you just want somthing that will run and be reliable. A variety of base mount mags will fit and operate well on them.
Early Cs and Ls had the Robert Bosch magnetos while the mid to late ones had the American Bosch mags.
The most common mag I see on Cs and Ls is the big Case 4CMA mag from a LA or early D series. They run well, are a direct bolt on and are pretty dependable, although parts for them are nearly nonexistant.
MMark
12-25-2004 13:53:21
What year is it? Could be one of three or four different types. Let me know, I could have what you need. I have many different mags for every make and model.
Nicholaus Sowder
12-26-2004 06:00:16
 Re: How is it to find a magneto for a Case C or L? in reply to MMark, 12-25-2004 13:53:21
Where is the serial number on a Case C or L? Thanks
DrCyKosis
12-26-2004 06:17:32
 Re: How is it to find a magneto for a Case C or L? in reply to Nicholaus Sowder, 12-26-2004 06:00:16
The serial number should be on the tag on the back of the toolbox if the tag/toolbox isn't missing.
Early Ls ('29 only I think)will have the serial tag on the R/H side low on the front bolster
If the tag is missing, Cs should have the serial number stamped on a pad on the R/H upper rear corner of the block right at the head. Ls will be similar, but at the forward L/H corner. I hope I got that right working from memory, it's kinda cold out to go check right now.
DRM
12-25-2004 13:52:16
I have one for the LA.I think that it will fit.
