Dc case question
ted
09-01-1999 06:27:22
I resently aquired a DC case, I was wondering if it is a positive or negative ground. The cables are rotted off and I didn't want to ruin a generator.
Also, what is the wiring diagram for the plug wires, It just don't sound right, It might just be bad plugs also. What is the speed of the belt pully, I want to check the engine rpm, or is there a better way?
Lastly, what fluids do I use 30w engine 90w rear 75 fluid hydro?
Thanks
Jason Karels
09-01-1999 10:30:36
 Re: dc case question in reply to ted, 09-01-1999 06:27:22
The DC that I have is negative ground. All of the other Case tractors that I've used follow that same system, so you should be safe to wire up as a negative ground. If I remeber right, the terminal for cylinder 1 is either top-right or bottom-right. My cap has the number 1 stamped on it. Once you find #1, go COUNTERCLOCKWISE around the mag cap. The firing order is stamped on the side, and it starts from the front of the tractor. I think it is 1-3-4-2, but I'm not positive. Check cap for s, etc. On a mag, the belt pulley is about the only way to measure RPM. Again, I'm not sure, but I think idle is 500 and full speed, no-load is 950. If I find time tonight, I'll get thos numbers for you.
Jeremy
09-01-1999 10:17:37
Case D series are negative ground. The firing order is 1-3-4-2. 30w or 15w-40 oil is fine for the engine, 80w-90 for the transmission, and an equivalent to the Case-IH hytran for the hydrualics will work. I can't remeber the belt pully speed, but the PTO will work too. I think it runs at 541 rpm. If it has a distributer instead of a magneto you can check the rpm's from that too.
