Case 1070 info
John Hobby
12-24-2004 08:15:45
OK guys,
I looked at this 1070, 1975 he said. 7,400 hours, rubber 70%, dry engine, no leaks to be seen. Filters had 06-04 on them, cab, AC good he said, interior looked good. It had 4 speeds with three choices per speed. He also said if you tap the breaks, it down shifts, nice for baling. Steering wheel adjusted, glass looked good, tin good. Too cold to start, battery dead. He has had this for 5 years and is only selling if he gets what he wants. He cuts 140 acres of hay and does not need to sell. I have a Vermeer 503I round baler and need a little more HP, baling now with a 584IH and she does it but she is working. I figure 100 hp is good, leaves me room for larger baler or disc mower. What do you think. He is asking 9,500 for it and it is a big tractor. I have a Dodge with a 26' goosneck, 14,000 rated. This tractor list at 9,500 pounds, heavy. Probably will drive it to where I need. It is two wheel drive, unlaoded tires. Any advice, I know I spoke with Hayman. Thanks and Merry Xmas.
Hayman
12-26-2004 11:38:24
 Re: Case 1070 info in reply to John Hobby, 12-24-2004 08:15:45
Well that does sound like top dollar for that tractor with those hrs. at least up here. It would have to be in pretty darn good shape with the history of service records etc. since new. If it had like 4000 hrs then yes I say that would be a good deal for sure. We've all seen stuff with high hrs. that looks great and was taken care and stuff wtih low hrs that looks like crap and never had a dime put into it. Does it look like it was maintained over the years?? Was the hyd. oil changed every 1000 hrs and the hyd. filters every 500??? I've seen some where both was never changed for 20 years!!!
The thing is if you spend 9500 then take out haying and find something wrong your gonna have to invest more $$. Not like if you picked up for 7000 then you have some room to play with regarding repairs etc.
7400hrs is getting up there when it comes to the powershift. But it all depends on what it did the last 30 years, heavy pulling loader work or just lighter stuff like haying. I wonder if the powershift had been pulled apart and serviced over the years?? I know one guy who likes to pull them apart and check them over at 5000-6000hrs if they were worked hard or used as loader tractors daily. Not saying there're shot at this time but this way you catch things early, the repair cost is much less and then you have no worries about down time. I pulled my 970 apart at around that 5000 or so hr. range. It was used has the main tillage tractor for 4 years them just loader work, haying, seeding, some lighter tillage and well everthing. It was making a funny noise I felt when pushing snow one winter. You get to know how things sound over the years. My dad figured don't worry about it was nothing. However that winter it was bugging me so I pulled it apart and found a snap clip had failed on the front C1 clutch allowing it to rattle. I replaced it with a new style upgrade. I took it all apart and put new seals in. All the clutch packs, gears and what not were like new still. I replaced a bearing and some bolts as the dealer recomended to do so when apart. Stuck it back together and its been fine ever since. The old case powershifts were one of the eaisest to work on.
For what you want it would be perfect. They are very popular around here for a haying & round baling tractor. I would sure like to get another.
I would make sure you drive it first and have him put in a new set of batteries. See how the engine runs and powershift works. When you start it up see how it shifts into gear. Then make sure once you shift it in gear it takes off right away. If seals are old and worn in the powershift unit it will leak down when it sits over night etc. Then when you go to start in the morning you have to wait a minute or so for the oil to build back up etc.
I never heard about tapping the brake pedal???? The way the clutch pedal works it down shifts the powershift from 3&2 down to 1 when its pushed in all the way.
I'd say it would be a tough call on this one. Do you know the guy personally?? So much depends on local market and how it was cared for over the years. That unit up here at a farm auction would probably go for 6000-8000 with no loader Cdn funds though.
I'd say take it for a drive and make darn sure it all works like a top for that kind a money. Thats probably more then what the tractor cost when new!
mudlogger
12-24-2004 16:33:31
In Texas I bought the same model for $5000. But it was a between friends deal, so I think I got a pretty good deal. The tractor is very reliable. The cab is comfortable as long as the a/c is working. Winter time it is kinda hard to see out of cab with no defrost. The down shift that you mentioned is the handiest and best thing about the tractor. I rely on it constantly. The PTO stays the same speed regardless of groundspeed as long as the rpm"s are kept constant. I use mine to bale with and it is always the most comfortable tractor on the ranch. The weak link is the transmission but as long as you don"t abuse the linkage, you"ll have few problems. For cheap usable raw horsepower, it can"t be beat. Hauling on a trailer is a big pain as it"s physically much bigger and wider than most tractors, so moving it around sucks. I know that from experience. Keep that in mind if you are working in areas far apart.
John Saeli
12-24-2004 09:34:57
Hey John: For a 30 year old tractor with that many hours, $9500 is too much.
970 crew
12-27-2004 16:02:55
 Re: Case 1070 info in reply to John Saeli, 12-24-2004 09:34:57
There is one up here, (Wisconsin) that is possibly for sale. It has 2500 hours on it no cab and is in nice shape for 5500.
John Hobby
12-24-2004 10:02:01
Yeh,
A few guys have said that on my last posting. I live up in New England and that really seems to be the going price for what is up here in that HP. There are some IH 1066's for $8,000, some 766 for the same. It seems that price brings age with hours. This is a clean tractor an downed by a guy who owns the dealership, it is his. There is a IH 3688 for $10,500. No cab, just ROP with hard top. 1985 model. I do not know how many hours but I know it is a little more HP and weight. What do you know about the auto package that drops the tractor down a gear when the brake is hit. Good success or repair issues ? Thanks
John Saeli
12-24-2004 18:54:51
 Re: Case 1070 info in reply to John Hobby, 12-24-2004 10:02:01
Hey John: I no of no option where the tractor was downshifted by using the brake. I'm sure what he meant was that by stepping on the clutch, the Power Shift automatically shifted into 1st Range. The 1070's were available with either a Mechanical 8 Speed Tranny, or the 12 Speed Power Shift. Sounds like this 1 has the Power Shift. If you are in New England, you should come into New York for some cheaper power. A tractor with that many hours on it could be a money pit down the road. Has anything been done to it?
drdiesel
12-24-2004 16:14:49
The 66 series IH tractors are good investment simply because of the sheer numbers of them, and the number of people who can fix them and supply parts for them. I think you could just about buy a complete tractor through the aftermarket if you really needed to. The case may be a different story. I have a customer who is buying 9 thru 1370's because they are cheap ($6000-$10,000) and he knows a guy who is crackerjack with them. He often sinks a lot of money into them, but from a different standpoint, he knows he can get them fixed and that they are relatively reliable--unlike the newer iron he has around the farm.
