Case 930 Draft-O-Matic
Brangus1
12-23-2004 06:15:06
Excuse my ignorance but what is the " Draft-O-Matic " ? I've got an idea but maybe somebody can confirm.
Roger H
12-23-2004 07:02:12
 Re: Case 930 Draft-O-Matic in reply to Brangus1, 12-23-2004 06:15:06
It is the 3 point hitch system on comfort king Cases', it automatically senses the load or "Draft" the pulled implement such as a semi mounted plow or mounted field cultivator as much as 600 times per minute and adjusts the depth in a tough spot and will transfer weight to the rear wheels for a boost in traction. The earlier Eagle hitch Cases' had no draft control or sensing, you put them at the position you wanted & that's where the stayed.
