Will it push a 8 ft 3pt blade?
HobbyFarmerInWI
12-22-2004 17:48:39
Will my 57 300 (311) gas handle a three point blade which is 8' long? Plan on using it to move snow.
Thanks
C. Amick
12-23-2004 05:40:52
 Re: Will it push a 8 ft 3pt blade? in reply to HobbyFarmerInWI, 12-22-2004 17:48:39
As long as you have enough weight on the rear axle and chains, it should do fine. The problem I have with my 300 pushing snow is that I don't have fluid in the tires and no wheel weights. It does a lot of spinning.
Lincoln
12-23-2004 03:52:30
I have a 7' blade that I added 2' to on one side. That way I can still turn it around with the short end toward the tractor when used for pushing. My 310 handles it with no problem
BarryW
12-22-2004 20:22:46
I use an 8 ft blade on a 311b with a wide front. It works very good because it will reach past the wheels. It works best with drawbar removed and the top link set shorter than it would normally be. This allows the blade to lift higher and can turned for pushing. Look for a frame that allows the blade to rotate with out hitting the tires.
Bruce Nelson
12-22-2004 18:25:17
Hobby Farmer, If you were buying a blade and had a choice, I would suggest a 6 footer. If you have an 8 footer, use it. It will be a little large but, you only have to take an 8 foot swipe, the first pass. After that you can take as little as you wish. I have an 8 foot blade on an 8500 lb. 64 hp tractor and it handles it well. Bruce
HobbyFarmerInWI
12-22-2004 18:50:52
 Re: Will it push a 8 ft 3pt blade? in reply to Bruce Nelson, 12-22-2004 18:25:17
Thanks Bruce,
I am looking at a 8' blade at an upcoming sale. I like it because it can be turned 360 degrees. I was thinking if the snow was very deep, I could increase the angle of the blade, thus taking a smaller cut with each trip
JGarner
12-23-2004 07:14:40
 Re: Will it push a 8 ft 3pt blade? in reply to HobbyFarmerInWI, 12-22-2004 18:50:52
We used an 8ft Danhauser behind our SC to plow out our mile long driveway in Northwestern Colorado. It did just fine, except we used it like road grader mostly. Angled over to catch just left of the left rear tire and pushed snow to the right side. Around the house, barns, etc it was reversed and used like a dozer thought to push flat. Danhauser was great fo this since you could change angle and reverse from the tractor seat and never had to dismount.
It worked just fine. According to Tractor Data our SC was 4 HP less than the 311, but 800 lbs heavier plus the fluid in the tires.
Dr Cy Kosis
12-23-2004 07:05:36
Be aware that a lot of the time an 8 footer won't clear the tire or drawbar to turn it aound while on the tractor. Mine will side slide so it can be done, but its a lot of work to actually get it done. Its almsot easier to drop, spin and re-hook than slide, spin, slide, re-level once youve dealt with the dirt and rust on the bolts and in the guides.
HobbyFarmerInWI
12-23-2004 09:05:59
 Re: Will it push a 8 ft 3pt blade? in reply to Dr Cy Kosis, 12-23-2004 07:05:36
Again, thanks to all who responded. Wish me luck when the sale comes up.
