Diesel engine will start and run but not at high
jnewark
12-22-2004 07:37:54
had this email from a friend..he bought an old case backhoe.. what is going on,, where should he look.
"I recently replaced the injector pump and all of the injectors, but it still does not want to run properly. It will start and idle fine, but that is about it" he also said when the throttle is advanced it will cough and belch...
thanks in advance
Dr Cy Kosis
12-23-2004 07:14:09
 Re: Diesel engine will start and run but not at h in reply to jnewark, 12-22-2004 07:37:54
You didn't mention whether it was smoking heavy or not. If its blowing lots of black smoke check the aircleaner.
I once climbed aboard a dozer that wouldn't hardly even move itself and was smoking heavily. I removed the aircleaner element and it weighted about 40 lbs! I couldn't beleive anyone had been running the machine like that. Replaced the element and it was fine.
johnnydindemingwa
12-22-2004 18:00:59
could be particle in fuel return line. THere is a very small restriction that catches things.
DAVE Z
12-22-2004 07:55:58
There are a number of things that cause this timing " poor fuel ,was old pump faulty " bent line , poor filters that would have been changed right repacement pump was checked out right
petetx
12-28-2004 20:29:38
 Re: Diesel engine will start and run but not at h in reply to DAVE Z, 12-22-2004 07:55:58
Check the fuel return line if it is plugged it backpressures the system won"t let it come to speed
