Hydraulic and gear oil-what to use?
Colby
12-21-2004 22:30:28
Hey all,
I have a 1944? Case VAC tractor, row crop model but with the wide front axle. I am wondering what kind of fluid to use in the hydraulic system and the tranny/rear axle. The casing between the engine and transmission has a really super thin oil in it, almost like it has gas or solvent in it. The transmission, which I assume shares fluid with the rear axle, has a thick milky nasty oil which I assume was once 80w90 gear oil. I need to know what to use to change these fluids out and how much. Thanks!
Paul f
12-22-2004 06:47:05
 Re: Hydraulic and gear oil-what to use? in reply to Colby, 12-21-2004 22:30:28
Hydraulic fluid (or Manual says Above 70 -20w, 32-70 -10w, Below 32 5w) for the torque tube.2 gal
For Trans/rear end I have two V-series Operators manual. The older specs 140w above 32 and 90w below 32. Newer manual 90w (7gals) all temps.
I am using 85-140 but she gets little winter use.
