Case 444 Snow blower help needed
Bobby S.
12-21-2004 11:40:36
Hi guys I need someone to sned me some photos or diagrams on how to hook this thing up. I am not sure I have everything I need and have yet to figure out what goes where. Please respond as soon as possible as they are calling for 6-12 inches tomorrow night and I want to get this thing running so I dont have to Shovel my way out. I can take some pictures and send them if that will help anyone out.
Thanks.
Bobby S.
12-21-2004 15:31:58
 Re: Case 444 Snow blower help needed in reply to Bobby S., 12-21-2004 11:40:36
Ok i have it attached but i can not get the belt tight enough. Can someone please help me out and explain as how to do this. Also it seems the pulley is off just a litlle bit is there a easy way to adjust this so it will run straight?.
Thanks
Bobby S.
Rol Farrar
12-29-2004 13:55:46
 Re: Case 444 Snow blower help needed in reply to Bobby S., 12-21-2004 15:31:58
The two idler pulleys are designed to run at slight angles.The belt travels from the blower drive pulley under the stationary idler, up to the left side of the engine pulley, then clockwise down to the adjustable idler and back to the blower drive. The adjustment is a spring tension on the arm of the adjustable idler. I hope this helps. My blower has a diagram decal on the left side of the frame. If additional help is needed, I could take some pictures, though I am about to dismount the unit to do some bearing replacement.
