cracked head?
nate67
12-20-2004 16:55:20
I have antifreeze coming out of the no.1 cylinder exhaust port. Just noticed this morning, but when I pulled the manifold looked like it could have been going on for several days. Is it the head or a seal or o ring. I"m not familar with these heads. Never had a problem before. 67" 930 ck
J.W. Grooms
04-26-2005 16:02:15
 TORQUE ON 1951 CASE VAH (VAC) in reply to nate67, 12-20-2004 16:55:20
How do I find the torque on the 1951 CASE VAH (VAC)Cylinder Head Bolts and Valve Cover Bolts?
John Saeli
12-21-2004 04:25:25
 Re: cracked head? in reply to nate67, 12-20-2004 16:55:20
Hey Nate: If it is running out with the engine not running it could be head gasket or cracked head. If it only comes out while running, you could add a cracked sleeve to the list. Just curious, does this engine get ether?
nate67
12-21-2004 04:41:57
 Re: cracked head? in reply to John Saeli, 12-21-2004 04:25:25
It only comes out while running. I use ether only when I have too. Haven't needed it this year. I've been able to park it where I can keep the block heater plugged in.
John Saeli
12-21-2004 05:31:45
 Re: cracked head? in reply to nate67, 12-21-2004 04:41:57
Hey Nate: I have my opinions on ether that some will argue with. I never use it, and I mean never. It only takes 1 time. All I can say is prepare for the worst, & hope for the best. Good luck.
nate67
12-21-2004 08:35:41
 Re: cracked head? in reply to John Saeli, 12-21-2004 05:31:45
thanks for the help
