Low Oil Pressure...Rod Bearings?
Glenn F.
12-20-2004 09:23:14
My SC has a little lower oil pressure than I'd like...22-23 lbs. when warm. I have the pistons out now for a re-ring job. Sleeves and pistons look very good. Rod bearings look OK but worn. I have not checked with plastigage yet but...A friend told me worn rod bearings are the most common cause for low oil pressure (assuming the oil pump is fine). Would you agree? Thanks, Glenn
Klyde
12-20-2004 14:24:40
 Re: Low Oil Pressure...Rod Bearings? in reply to Glenn F., 12-20-2004 09:23:14
10 PSI per thousand RPM was the standard on old gas engines. You should be fine.
dctom
12-20-2004 09:26:07
yes and also cam bearings but 22 to 25 not too bad for sc
